Just switched to a power commander.
Well I just finally got the money together to get both a power commander, and the big sucker (i'm a college student so I had to save my pennies...) anyway prior to that I was just running vance and hines shortshots slipons and of course the engine was lean. Now that I have the power commander on and new air cleaner its a BIG difference. No popping, backfiring or anything. My question is I could tell prior to the install that it was running lean and now that it should be a lot closer to what it should be is it a good idea to install new plugs? Mind you its only got about 8K on the original... Its cheap to replace them, but was wondering if it was necessary at all?
-LB
-LB
Brian McKenna
06-10-2010 10:38 PM
