lighting issues-help
1991 sportster 883,1200 kit
I changed the bars to drag bars,put on different seat.also replaced the rear brakes and caliper.
now when I turn on the key,the tail light flashes like a 4-way.
all the turn signals work properly,and the taillight and brake light work.
the only thing I can think of is a bad ground somewhere,or air in the brake lines doing weird things,I had to bleed front and back brakes,when I got the bike it had no rear brakes hooked up because the caliper was warped.so dont know if this was a previous issue.has anyone ever heard of this issue
update
ok this is driving me crazy,when you turn the key on all the lights come on,but the brake light imediatly starts flashing a sequence of 4 flashes,stops then flashes again,and keeps repeating
when you put the front or the rear brake on,it does nothing just keps flashing that sequence.
anyone have a clue?
anyone have a clue?
