Power Commander III question
Just installed PCIII on my 07 street bob. Got it from FuelMotto. Told them I have a V&H Phythons and the new Big Sucker by SE. Installed and bike fired up good. Let it run for a bit and then gave it alittle throttle. Still going good. No white or black smoke. Then noticed rear pipe next to head is RED HOT. Front one is normal. Is this normal?
This is absolutely not normal. What you are describing is cylinders that are not balanced for fuel delivery. When your Harley first starts it is on the warmup enrichment circuit, meaning it is dumping more fuel. If your pipe is glowing then the fuel adjustment for that cylinder is not right. I would either call Jamie and try to trouble shoot it with him or get the bike to a dyno tuner and get it tuned.
LazySundays
24
08-11-2018 07:08 PM
