Killed it dead
Killed it dead
Through my own inattention and stupidity I managed to run the battery all the way down to zero and leave it that way for a week. Left the ignition switched on while working on the bike and walked away. A week later I got home and noticed and hooked her up to the battery tender. It appears charged again but I'm wondering what impact this will have on battery life, not to mention anything done to the ignition. The battery is two years old and has spent its life on a battery tender and has never given a hint of a problem up til now. Any experience with this? Thanks in advance.
"Usually" when batteries are drained and left that way for an extended period of time they will incur permanent damage. In your case, the duration might not have been long enough to cause you a problem. I'm sure there was damage to a degree, but not enough to warrant replacement. I'd unhook it from the tender for a week or so and see if it discharges. If it does, you will have to replace it.
As for the ignition and onboard electronics, I'd consult your dealer for an opinion, or perhaps someone here has knowledge of that probability.
Thanks, good idea. I think I'll give it a few more days/cycles on the tender and then try to see if it will hold. I actually had it in the accessories position so maybe less chance of anything important going wrong.
No it just drained it and will recharge without damage to anything; should make the key not removable in accessory-did that once on the XL. Tenders should not be used to charge (hence the name "tend"); use a real trickle charger (until at least 60%charged for the tender if ya really gotta use it).
CaffeineBuzz
07-13-2019 10:16 AM
