How do you turn off the alarm to work on the bike?
I've got an '08 FLHRC with factory installed Security System, and dealer installed SmartSiren.
I want to add the HD brake light mod (red lenses for turn signals, module to use turn signals as brake lights).
Instructions say to remove the maxi-fuse, and disconnect the battery cables. I have the service manual, followed the instructions, and when I pull the maxi-fuse, the siren goes off. Impressively in the garage! Even though the fob was in the fork lock.
What's the trick?
What's the trick?
As soon as you remove the batt cables,,yes the alam will sound,,for approx 30 seconds,,I think,,when my friend did that to his the siren faded shortly after because its internal batt died down,,,
there is some instructions floating around on the forum here on how to disable for maint. but I dont remeber exactly where,,,do you have the owners manual?? it should say in there...
Install the module with the battery connected. I done it on two bikes.
Most of the disconnecting battery stuff is just B.S. Cover your ***.
In my opinion.
With the Ignition off there is no power right.
HD says to disconnect the battery before working on the clutch etc. I just did not try to start the motor when I was working on It. Duh
In my opinion.
What's the trick?
What's the trick?
