Rear brake module
Old 02-13-2009 | 09:23 PM
Romark's Avatar
Romark
Default Rear brake module
I want to put one of those modules that turns the rear turn signals into brake lights as well. turn signals. I have a LED rear tail light. Will one of these modules work with a HD LED tail light? Which brand module should I use?
Thanks,
Mark
Old 02-14-2009 | 07:45 PM
Romark's Avatar
Romark
Anyone?
Old 02-14-2009 | 10:12 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Use the HD Run/Turn/Brake module.... It is compatible....
Old 02-15-2009 | 01:14 AM
Romark's Avatar
Romark
Will check it out.
Thanks
Old 02-15-2009 | 01:24 AM
anubisss's Avatar
anubisss
Had the hd one it burned out after about a year.
Old 02-15-2009 | 08:57 PM
Romark's Avatar
Romark
I would like the option to flash the brake lights and the HD one doesn't do that from what I have seen
Old 02-16-2009 | 12:00 PM
Shovelhead Bob
Then you need to us a Kuryanin Brake Light Modulator....
You didn't specify that in your initial posting.......
Chris Petersen
04-09-2018 03:22 PM
Trapperwny
08-11-2014 10:28 AM
BigDaddyMike
05-05-2010 11:12 PM
redmustang1990
02-26-2009 12:41 PM
jto667
02-15-2009 11:33 PM
