Factory HD Alarm with proximity addon?
When I get my bike I plan to have them instal the HD alarm w/the paging system. I also want to put in a proximity sensor so the alarm is sounded if someone comes within a few inches of the bike. Would HD's alarm be able to support this or should I have an aftermarket alarm system installed instead? Thanks.
RE: Factory HD Alarm with proximity addon?
HD's alarm is only compatible within it's own components... The TSSM is the heart of the system, and then you have the add-on siren and/or pager... To put in a proximity alarm and attempt to interface it could, not saying it will, but it might cause more problems than what they are worth, unless you are going with a set-up that IS COMPATIBLE with HD's TSSM system.... If they cannot validate or verify, and the system needs to be spliced into your already exixting harness, I would be VERY Cautious....
