starting issues
starting issues
Hey all, new guy here with a starting issue on my 2001 softail standard(carbed) I bought last month. The bike has started fine since I bought it but today I go to start it and nothing, turn the ignition switch I have lights, gauges the works but the bike won't turn over, I wiggled the switch around and it caught a few times and turned over once or twice then nothing. Anyone have any ideas about what the problem could be, I checked the battery cables, the wiring from the switch and the fuses and everything looked fine. Thanks
got it resolved, took the ignition switch apart and srubbed all the contact points with steel wool, the took a small flathead and bent the connectors in the female end a little, put it all back together and bam works like magic, then went to check the air pressure on the back tire and the stem pulled out, hooray, had to take the wheel off and ended up getting a new tire because the old one was shot, lots of fun someday it'll get ridden
spike95
11-29-2008 02:28 PM
