Engine miss
Old 01-25-2009 | 02:51 PM
bamabadboy's Avatar
bamabadboy
6th Gear
Default Engine miss
My ride has developed an engine misss. Does not happen under load, just when cruising . It spits "pssst." Idles OK. I do not get any warning lights. Happens when the engine warms up, not cold. Battery, cables, and plugs are OK.Thanks for help.
Old 01-26-2009 | 10:29 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Make sure all of your ignition/spark plug wires are on tight. Is you bike carbed or EFI?
Old 01-26-2009 | 11:24 AM
KBFXDLI's Avatar
KBFXDLI
If your bike is carbed, I would look at jetting as it may be a "lean miss". If it is EFI test your fuel pump & system then look into your intake sensors.
Old 01-26-2009 | 12:30 PM
CndUltra95's Avatar
CndUltra95
If your bike is EFI, check the wires connecting to the throttle ody.
HD calls it the wiggle test...the wires become brittle and crack (short)inside the sheathing. Use a thin wooden dowel or a chop stick from chinese take out to prod around under the fuel tank while the bike is running to determie if this is your problem
Rob
Old 01-26-2009 | 03:51 PM
KBFXDLI's Avatar
KBFXDLI
Rob
Always a good idea NOT to eat with the chopsticks after the test...
Old 01-26-2009 | 09:40 PM
bamabadboy's Avatar
bamabadboy
6th Gear
Ride is EFI. thanks for the tips. Will check them out.
Ex11b
06-09-2016 10:19 PM
Calavera Negra
08-18-2015 11:55 PM
stevepacman
08-22-2011 07:06 PM
joebotics
08-01-2011 09:02 AM
paul_scooter
09-07-2007 08:30 PM
