tach install problem
Ordered a Drag Spec. mini tach for a 00 deuce and had installed by a indy. I was gonna attempt it but it became over my head when things like single fire and dual fire ignitions systems were mentioned. I ordered a tach adapter as well and exchanged the first one for the crane cams adapter after talking to tech support. Anyway the mech. installed tach without the adapter, said it wasnt needed however the tach doesnt register over 2000rpm. At 85mph in 5th gear tach showed 1800 to 1900rpm, I wish. Anyone ever run across this problem or is there something i could mention to the mech. that needs to be done or could this be a defective tach? Thanks for any insight in this matter.
Thanks for the explanation. Will check today if the mech. will install the adaptor at no charge since it was his mistake.
Back to the mech. and explained problem. He said that the adapter was for a 3 wire coil and I had 2. Reguarless he rolled in the back and instlled the adapter and it started working like normal. He's a custom builder and said he's wired them straight several times without any problem. Anyway problem solved.
Just a note that there has been some issues reported when using the speedo connector signal, sometimes its works, sometimes not. Pin 3 of the ECU connector is the ECU tach signal and that seems to always work, you may want to run your tach pink wire there instead. You may need to get the right kind of pin as I don't think the larger ECU connector pin is included in the HD tach kit.... at least it wasn't in mine..
Thank You
Just a quick thank you to the guys that sent me the information on my Tach problem. I do not know why Harley hasn't made some kind of statement on this subject except for the fact that they might want you to bring the bike to them somewhere. I finally found out after three days of looking what you guys said in only a few minutes. The Pin #3 is shown in a 2004 softail book but not in any newer books for the year of the bike. Harley is 2 years behind on all of the little extras that are mostly chrome for that years bike. I had the same problem with the Tach bracket. After getting two different brackets from Harley they finally showed up in the 2010 book for the Deluxe. Again Thank's for your help this forum is #1 in my book and I will continue to monitor it for education on my bike's. FlashSr. Boston,Ma.
