05 ultra relays
my recollection is yes they are the same. can't remember though if they are 87 or 87a relays. the difference being 87 is 4 prong, the 87a is 5 prong. now with that said, I'm almost positive they're wired differently. so if your question is "i'm having a problem and want to swap relays to see if that will resolve the problem" then yes you should be able to do that....
as long as they both have either 4 or 5 pins on it, they'll be the same. don't substitute a 5 pin for a 4 pin and vice versa. actually unless the pin configuration is different and proprietary you could get a bosch relay from AutoZone that will last longer. that's what I had to do with the fog-light kit I bought from HD. 2 relays failed in less than 2 months. Finally said screw it after spending $20 per relay to replace it, and just went to AutoZone and got one I knew wouldn't fail. Bosch is by far the leader in relay technology for automotive use.
