TTS question for Glens
#42
AFR settings
Once the V-tune is complete you can then re-set them to your desired normal operating AFR's.
B
#43
Any cell that cannot be set to 14.6 cannot be tuned with the factory switching sensors. This will also screw with the adjacent cells too! The ECM just does not switch off then on, it works on a weighted average type system. There are also other behind the scene limits that may take effect while the engine is running event if the cell is set to 14.6 so one must know whats going on as it may not be at 14.6 just because you put it there!
Like I said before it's just not that simple!
#44
#45
Location: Back in the Good Ole USA. South Carolina to be exact.
The VE information does come from the O2 sensors doesn't it?
Not trying to debate anything here, just want to learn.
#47
Take any 4 cells of information and the ECM does what's called a weight average to produce the values that it uses. Now mind you that's not all it does but this should give you the basic idea. So it takes all 4 values and comes up with an answer. So if any of the 4 cells are not 14.6 on the AFR table the data being returned is open loop data and the O2 sensors are not being used. If they are not being used you cannot tune with them.
OLD 96
01-07-2018 10:50 PM
archergodwin
03-28-2009 03:02 PM
