TTS question for Glens
V-Tune calibrates your VE tables correctly so that the bike will run off the base calibration like it should. With that said every bike is different and may like something a little different to get full power from the bike. You can richen or lean the motor with the AFR and PE AFR tables after the VE's are set correctly to gain that power but it will not always be the same. Mastertune has a lot of power but remember you only need to use any part of it you like so it's only as hard or complicated as you make it.
If you want max power output you can do it on the road or on the dyno, it's all up to how much your willing to do or willing to pay someone else to do. The need to use another device to tell you the AFR ratio makes it easier but it is not necessary. Just as the dyno is not necessary but it makes the job much easier to get all there is to get.
Just remeber back a few years when bikes with carburators were tuned without any of these measureing devices. They ran great and got good mileage when properly tuned. Now with the measuring devices it made that same tune quicker and easier to do but the outcome was the same. Now we do it with computers and let them tell us what to do!
Now that VTune is packaged with TTS, any reason to use Twin Scan II also?
And, how do you determine which calibration file to use as listed on TTS website? : http://www.mastertune.net/files/calibrations.asp
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Location: Back in the Good Ole USA. South Carolina to be exact.
Ok, now this all brings a couple of questions to my mind. It would seem that VTune uses data provided by OEM Narrow Band O2 sensors to optimize the VE tables. That being said;
1. I have used my SEST Pro to log data and make adjustments to my VE tables. How is the VTune and TTS any better in this regard?
2. Is the data in the VE tables constant, in that it will be the same for any AFR?
2. The OEM Narrow Band O2 sensors limit us to the 14.7 AFR, but I really want to get closer to 13.5. How will the TTS help me do this?
Frank, thanks for the quick response. I want to clarify a couple of things so I am sure I understand.
1. Populating the VE tables with the correct data would seem to be critical. I am guessing that VE is based on the various mechanical factors affecting air flow in and out. Therefore once these values are set, they remain constant wherever the AFR is set.
2. Not sure what you mean by "after you've synced up the VE table to the AFR table"
3. Once my VE table set, I can go to my AFR tables and copy 13.5 to all the cells, and I'm in the ballpark?
