ECM Update for True Duals
But loading a base map which is proper for the equipment employed is certainly far better then not doing so.
Locate the proper base map in the SEST software and load it into the ECU according to the instructions included with the software. Changing the exhaust system type brings about changes in the fueling relationship between the two cylinders and this must be addressed.
I have no doubt that dyno testing by a trained technician is the best route. However, there seems to be many riders here and on other forums who have been successful with the 'do it yourself' approach. It can't be THAT HARD, because too many have done it.
There are other parameters than can/should be fine-tuned, but the biggest factor is the Volumetric Efficiency tables. If you're comfortable doing some datalogging and subsequent fiddling, you can always get a http://daytona-sensors.com/Twin_Scan2.html TwinScan II+ kit. It'll cost (without shopping/checking around) about as much as a dyno tune (or two) but you'd have it and you can use it over and over again, on your and other bikes. Just a thought.
You could also do basically the same in a more basic manner by datalogging with your SEST and, between making adjustments and reseting your AFVs, get your VE tables closer to what you need from the base map (assuming it's not close enough). Feel free to discuss this here if you want.
Jim Dawson
19
12-06-2007 09:01 PM
