Kuryakyn Light - Need help finding "Run" wire
Hello,
I have a 2005 FatBoy and have a lighted license plate frame that needs access to the "Run" (+12v) wire and ground wire. The instructions say to tap into these wires "Upstream" of the 8 pin connector that connects the rear fender harness to the main wiring harness.
I do have the service manual for my bike (2005 Softail Models) so if anyone could point me in the right direction I would be very grateful.
You should have a wiring and harness schematics in the back of the service manual. Also a table that references the connectors on the bike. Just locate the 8 pin connector, and pinouts are identified. You should be able to trace out the orange/white wire back to the ignition via accessories fuse. hope this helps also..
