TTS Mastertune Information
Old 01-06-2016, 07:40 AM
rigidorbust's Avatar
rigidorbust
rigidorbust is offline
hey all, building a 113 with 10.5 comp ,50 TB with 5,3 injectors, t-man 625 cam,beehive valvesprings and fullsac 2" full system. slightly ported head.
So i wonder ,,Is FAB 009-01 the closest map to start or is there another map i should install?
  #6392
Old 01-06-2016, 08:02 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Received 2,043 Likes on 1,105 Posts
Don't forget to tell us what bike model and year.
  #6393
Old 01-06-2016, 08:15 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
well Wiz.. it's the one that he rides of course!
  #6394
Old 01-06-2016, 08:20 AM
Mr. Wizard's Avatar
Mr. Wizard
He doesn't look like he rides a Suzuki either but... if he wants a number he will need to cough up the required info.
  #6395
Old 01-06-2016, 09:02 AM
rigidorbust
2012 cvo road glide custom
  #6396
Old 01-06-2016, 09:27 AM
Mr. Wizard's Avatar
Mr. Wizard
The FAB009 should do just fine.
If you find the FAB running poorly then use the FAA009.
Do the cam tune and set your IVO then do some VTunes and see how she shakes out.
rigidorbust (03-21-2016)
  #6397
Old 01-06-2016, 09:44 AM
rigidorbust
thanks.
  #6398
Old 01-06-2016, 10:30 AM
Mr. Wizard's Avatar
Mr. Wizard
Yup.... good luck with the build
  #6399
Old 01-06-2016, 02:11 PM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
Veteran: Marine Corp
Is there anywhere in this thread or site that explains how people should pick their starter cals? Even with IVO/ IVC. The TTS direction are still on point, but maybe explaining why would help the thought process for some. I still use the cam specs for the bike and the SE catalog that gives me the HD cam specs, and the cut and past features. Some times close enough is the best you can do, and using the features in the program helps sort it the rest of the way.
  #6400
Old 01-22-2016, 08:13 AM
rigidorbust
from the Harley manual, disconnect the ACR before loading a new map,,,,??
what can go wrong? planning to do the programing this weekend,, advice needed
Quick Reply: TTS Mastertune Information
