TTS Mastertune Information
#6021
#6022
So from what I can tell Vtune3 just removes spark....
How do you guys go about adding some advance? Do you add any at all?
Logically it seems you could highlight all and add a little at a time until you see some knock and then back it down?
I understand that not in all cases will the most advanced timing result in the most power....
#6023
Was wondering if someone could take a look at my .MT9 file. Its based off around 5 Vtunes. Just wondering if things are going well & I should continue Vtuning or ? When pulling vtune files onto data master the IVC-3 #s seem to spike alot. Dont really know how to analyze that. Then when pulling into Vtune 3 I typically go advanced, load the current .dm3 and then start comparing Vtune results (as Ill have around 3 just from running around.) Depending on if I load 1,2, or all 3 Ill get different results. Understandable, but seems like some combinations negate what other may suggest. Also some may not show the EGR % change screen at all, but yet show VE changes that are greater than 5%... And everytime Vtun3 says to merge file and keep tuneing. I have not enabled auto extend at all at this time. Anyways would apprciate a point in the right direction. Let me know and Ill send the file and or upload any screen shots.
#6024
I totally relate to your story. I have a 2014 street glide and did the stage one with the power commander 5. It runs well but definitely feel it is not performing to its peak.
I have made an appointment with Doc for early May and will have the power commander removed and have a TTS put in, with Andrew 57's and a real nice dyno tune.
Can't wait..
Can't wait..
#6025
Can't wait..
Can't wait..
#6026
I don't understand why you aren't using auto extend. After the 1st or 2nd run I always use it to help blend other cells that I can't get to. Saves me a bit of work.
#6027
So set the CLBs after Vtuning or before or Vtune, set CLB, then Vtune again? I'm confused.
Here's a good rule of thumb. If you don't understand the table, leave it alone.
With a stage 1 bike my favorite setting is 684. This gives me a good blend of power and fuel mileage. With more than a stage 2 bike you must experiment IF you want to. I do find the CLB's a little lean for my tastes. Don't drive them above 780 or you may over drive your injectors.
I'll be away for a while guys and won't be answering much. We are dealing with family medical issues at this time and I'm needed elsewhere.
#6028
If you post a few of your dm3 recordings and your last VTune calibration using box.net then we can view what is happening. Without a view you will not get any comments to your questions.
Here is the link
https://app.box.com/s/9co8k5l2v9qrcr9khktuhg6x3fqioros
#6030
Open Datamaster2 and load the file
Save the file
Now open in VTune3 (1st selecting the base map you are running in your ECM) and then the tune file(s)
