TTS Mastertune Information
Old 04-08-2009, 11:32 AM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
At some point, I want a good dyno guy for my bike that is good with TTS. Norwalk sounds good.
This thread is holding up very well, I think.
Nerk is a hike to get to C&A . HAHA... no Centennial (I agree)? I live in Blacklick
  #592
Old 04-08-2009, 03:25 PM
Bluegrasser's Avatar
Bluegrasser
Bluegrasser is offline
Does the TTS allow you to enrich '09 bikes by reducing the AFR or do you maintain 14.7 and change the Lamda? Or both? Or neither?
  #593
Old 04-08-2009, 06:56 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
You can richen the AFR to 10.0:1 for now....Lambda will be in the near future
  #594
Old 04-08-2009, 07:29 PM
tanglefootrgu's Avatar
tanglefootrgu
tanglefootrgu is offline
Smile 05 -06 Upgrade
Steve or Doc,
Can either of you let us know how the 05 -06 upgrade is progressing? Also, is there any word on a map for 95" builds with Andrews 26 cams for a base map? I appreciate all the information that you both provide. dave.
  #595
Old 04-08-2009, 08:00 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Originally Posted by tanglefootrkc
Steve or Doc,
Dave
The 06 maps are completed to the MT7 format. I don't know when the SERT update will be released if that's what you meant....sorry.
As soon as the next Master Tune up grade is finished and released we will have the option to up grade our older maps....when this happens I will summit several maps using cams other than SE cams, But as of now there are no 26 maps in the tuning files.
Doc
  #596
Old 04-09-2009, 07:19 AM
vtwinbmx's Avatar
vtwinbmx
vtwinbmx is offline
Originally Posted by Doc 1
Yea I thought you where way high up by the way you hit cells in the 80 and 100% throttle position. Doc
Doc is there a way to tune 80%-100% closer to sea level or even at high altitude the numbers are not valid?
  #597
Old 04-09-2009, 09:16 AM
TickTock's Avatar
TickTock
TickTock is offline
Steve Cole -
Will the next update of the TTS software be able to retro to the old SERT and make it work? If not do you have a new estimate of when it will be available?
  #598
Old 04-09-2009, 04:21 PM
Duke of HD's Avatar
Duke of HD
Duke of HD is offline
Originally Posted by bwickes
Duke of HD,
It looks like you unchecked the "data filter enable" on the v-tune screen. That button should be checked according to the help files. When the "Data Filter Enable" is checked you do not get V-Tune data above 80 KPA or above 5,500 RPM.
I suspect that MasterTune believes that data can not be trusted.
Otherwise it is a good run compared to the 15-20 runs I have done on various bikes. Maybe get one more to confirm. Make sure the last run is a complete tune otherwise you could be chasing numbers up then down.
B
I looked and it is indeed checked? I will be making another run or two and double check that it stays "checked"
  #599
Old 04-09-2009, 06:36 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Your getting information in the 80% and 100% throttle because you are in a much higher altitude. When you are at wide open throttle you only get about 80 to 85kPa instead of 101kPa like I do here at sea level. The ECM comes out of closed loop at 90kPa so being in Denver you never hit that limit so it stays in closed loop in the highter TP%. It has nothing to do with the filter checked....mater of fact if the filter isn't checked V-Tune doesn't work.
Doc
  #600
Old 04-09-2009, 06:49 PM
Badmedicine's Avatar
Badmedicine
Badmedicine is offline
I have a 09 FXSTC and installed the AE176-002-B1 map, the bike runs great, no popping on decel and got rid of the heat issues, do I have to Vtune? It works so good as is I'm afraid of changing something for the worse.
Quick Reply: TTS Mastertune Information
