TTS Mastertune Information
#5301
#5302
#5303
9225 is the same as part # 2000008 so yes it will work. you will also need cable kit 9229 from kuryakyn.
TTS part #s are 2000008 for the device and 2000011A for the cable kit.
denniskirk, jpcycles, etc. all sell the TTS part #s, Kuryakyn is the only one that slaps their own part number on the product.
Sorry for reviving an old post but I have read through as much of this thread as I could
can somebody tell me is 9229 the same cable that I will need for a 2014 CVO Breakout
regards
Rod
#5304
Hey everyone...
Wanted to pass along some bad news.
John aka Wurk_Truk died from a heart attack between this past Tuesday early morning or Wednesday while sleeping.
John always gave freely of his tuning knowledge here and assisted many members.
Take a moment and reflect.
Thanks for your time.
-Wiz
-Wiz
#5306
The difference in the Touring cable is one wire was moved in the connector by the factory so they had to change the Touring cable part number.
#5307
#5308
#5309
Will it work, yes
Is this the best route, nope
Power Commander doesn't use some of the ECM wiring harness and cuts out your 02 sensors. Why would you want to do dat?
#5310
