TTS Mastertune Information
Old 04-29-2014, 02:38 PM
slyedog's Avatar
slyedog
slyedog is offline
Originally Posted by UltraNutZ
need to work on
front cylinder
2000 - 2750 RPMS 10 - 20% throttle position to try and smooth that out
rear cylinder
2750 - 3500 RPMS 10 - 25 % throttle position to try and smooth that out.
set your decel enrichment back to originals before vtuning any further.
Yeah I knew I had some light tps % to hit on low rpm which was hard for me before winter hit. I am hoping going 2 up and some good hills will help hit those cells. Mainly.my concern was changing anything else back to original and if tune was good other than those low map cells. I will set de to original for next v tune run and see how I do from there. Having a tach now should help with getting those low map cells as well. Thanks
  #4962
Old 04-29-2014, 05:14 PM
SIA's Avatar
SIA
SIA is offline
6th Gear
Ok been trying to read back as far as I can but don't see what I'm looking for.....
2012 flhx
2-1 exhaust
AC
Lunati torque/mid cams (I know cam selector should be at 3)
..... What file as starting tune? Duh-044?
Thanks
  #4963
Old 04-29-2014, 05:20 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
Originally Posted by SIA
Ok been trying to read back as far as I can but don't what I'm looking for.....
2012 flhx
2-1 exhaust
AC
Thanks
DUH044, yes...
  #4964
Old 04-29-2014, 09:53 PM
SIA's Avatar
SIA
SIA is offline
6th Gear
  #4965
Old 04-30-2014, 03:45 AM
Kiwirob's Avatar
Kiwirob
Kiwirob is offline
needs to be 3 IMO.
Looks like 2 to me - Rob
  #4966
Old 04-30-2014, 05:14 AM
jcav44's Avatar
jcav44
jcav44 is offline
Try setting it at 2 and see how it responds
5.3.3. Determining Intake Valve Opening (IVO) Setting:
To determine the optimum IVO setting, view the above graph and find the point at which the curve "breaks" and begins to head up at a steeper angle. That point should be the optimum IVO setting to use in the calibration. Note that in this example, the optimum setting is 5 as that is the "Inflection Point" at which the graph first heads upward. It is also permissible to set this one less (i.e. 4) using your judgment.
Can't hurt to try
Jaxson
  #4967
Old 04-30-2014, 07:00 AM
UltraNutZ's Avatar
UltraNutZ
look at the line. it's almost a perfectly straight incline from 1 through 3. 3 is where is starts a steeper incline. that's your sweet spot.
If you change it, crank up the bike and listen to it idle. Also crack the throttle a couple of times to get a feel for which setting is better by throttle response. Then select whichever is best in these 2 areas. Odds are you won't see a difference either way.
  #4968
Old 04-30-2014, 07:43 AM
Tipper1's Avatar
Tipper1
Tipper1 is offline
6th Gear
Originally Posted by Mr. Wizard
The SERT promo is dead. They do have a plan being considered for the Black to Blue promo. How/when and how much is still being discussed. This will be on the table right after the VT3 software release.
Thanks for the info Mr. Wizard. I will keep my eyes on this thread waiting for the time to upgrade.
  #4969
Old 04-30-2014, 08:29 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Received 2,043 Likes on 1,105 Posts
I see the small upswing at 2 but it's really small, micro small. This means the kPa swing is closer to 3 than 2. TTS does say if the first upswing (3 in this case) idles the best and gives the sharpest idle throttle snap then use 3. BUT, try 2 as well. You should be able to feel and hear the idle difference. Use the most smooth idle.
If this is a contest ... I'll side with Nutz here.... 3
  #4970
Old 04-30-2014, 08:33 AM
UltraNutZ's Avatar
UltraNutZ
that frying pan is exactly what my head felt like after pulling off and reinstalling the exhaust on that trike I put cams in Sunday..
Quick Reply: TTS Mastertune Information
