TTS Mastertune Information
#4771
Thanks for the answers. So from what I understand the can-bus is a faster system and has a few more monitoring points. Better for mapping the engine. The timing info will also be very helpful. From reading, I understand the o2 sensors have a limited range to be really effective. Do the sensors work like they should at .967, or is that beyond there range. I am still trying to figure out how they, tts, got the map to show closed loop at .967.
#4772
You will find the 02 sensor range is just fine. Also remember these sensors are the ones your bike will use after tuning so... use what you have to keep the ECM happy.
Your query about .967 is a good question. I too would like to know. It isn't due to the CAN system. If so other CAN systems could hit that range and still be in closed loop. I'll think I'll ask.
#4773
#4774
Various ECM’s with different controls both in software and hardware allow different things to be done. That along with O2 placement makes something work in one application while not in another.
Translation.. He tweaked the software and changed the 02 switching code because the location of the 02 sensors could handle it. Not so with other bikes and builds.
#4776
#4777
Sensors
Had a few days to think about this. The 02 sensors can operate from 0 to 1 volt. The last closed loop voltage (977 lam) is .791volts with tts. Say you wanted to run 960 lambda which is .809 volts, this is well within the range of the sensor. Is the ECM the sticking point of not being able to expand the monitoring area? I just find it hard to believe that the ECM can't be adjusted to to a wider range. I haven't had a chance to look at the dyna's exhaust, but I can't imagine them moving the 02 more than an inch or so just because of the motor/trans configuration. If they moved them a lot closer to the head wouldn't the burnout/melt quicker? Maybe i am trying to read into this too much.
#4778
Think 3 dimensionally on the sensors. Don't forget about up and down then sideways. Even a slant will effect sensor readings at different RPM's.
As far as the ECM adjustment... It's either off or on. It either uses the data or it doesn't. It is always reading data. That's all software driven.
However, you can adjust your AFR/Lambda by adjusting the table. This is what the ECM will adjust to when operating the bike.
Over thinking it? Maybe... there are just somethings that must be taken for granted before it blows your mind. We talk about so few of the capabilities of the ECM and the TTS and there are hundreds of internal software switches that are turned on or off depending on the starting library calibration.
I don't understand the fermenting process of beer but it sure is good on a hot day.
#4779
#4780
