TTS Mastertune Information
#4272
I was able to beta the FR but my beta copy will be different than the final version. It will go like this...
2014 Touring calibrations release then the new TTS 3 software release which include a new Flight Recorder, VTune, DataMaster and Mastertune software. There will be a new firmware release for HD06 so it will work with the Flight Recorder that will accompany the new TTS 3 software. All this will be compatible with the BLUE TTS dongle. Some of the new software upgrades will work with the BLACK dongle as well.
The new software will work and look a little different in some ways but will be the same great product with more exciting results.
#4273
#4274
To answer... The 3 release will replace everything so that will be all you need.
All the old data and calibrations will work with the new software they have in the past.
What will be real nice is to have the choice to record data with or without a computer attached to the bike as I've been doing now. I highly prefer without.
#4275
Thanks. Once the flight recorder is out, do you know the recording time limit ? I would assume around an hour? When I have asked tts, all I get is it is still in beta. As a beta tester, it seems you are very fond of the capabilities. With your knowledge, and experience I am excited to use it. Just hope it comes before winter shuts me down. On a positive note, it will be something to look forward to in the spring if it comes out too late.
#4276
The simple fact is it will record longer than you want to record data. The fun part is you will be able to turn the bike off, grab some lunch or fuel then start the bike back up and still record data. Once you return from recording you take the TTS off the dongle cable and put it on your computer and download the files from the TTS into DataMaster. Since there will be several files.... you will get into VTune and add all the files you just recorded for generating a new .MT8 VTune file.
More and exciting news with the TT3 software will be solidified as it becomes reality but just as a tease... it will do many functions automatically for you while VTuning. If you are off on your cubic inches due to high VE numbers it will automatically change the CI for you and the VE tables will be adjusted automatically at the same time. It will also work your EGR tables, no more looking at tables in low kPa and making guesses to increase or decrease EGR numbers... There is more but I'm only privy to so much info.
#4277
#4278
#4279
#4280
