TTS Mastertune Information
#4011
#4012
Hey mr wizard, I bought the tuner a couple years back for my 2010 limited. You helped me out back then and sent me a map of a tune that you where using on you scooter at the time.
Bike runs real strong but the heat from my 2-1 bissanis are unbearable when outside temps are above 80 to 85 degrees. I haven't tuned it since then but only had a chance last couple years to get it out a couple times a year being from Montana. I need more play and less work for sure!
Should I start over on the tune? Any suggestions, to much lean you think? Hell, I feel I been away from this to long I'm feeling stupid!
Thanks
Thanks
#4013
Thanks
Thanks
#4014
Thanks
Thanks
If they just got to where they were hotter than before you can clear your AFV's using datamaster. This will take you back to a fresh calibration and so you don't need to flash again.
If you think the bike has gone through some sort of metamorphosis then you can VTune to your hearts desire.
I'll bet the pipes will still be hot.
#4015
Dan
#4016
#4017
Help with base map.
Can somebody please help me with a base map for a 2005 SE Electra Glide Classic 103 with Reinhart Tru Duals? Also any advice on trying to tune an open loop system would be much appreciated. I have tuned a couple of closed loop bikes with pretty good results but I have never tried an open loop bike. Thanks in advance for any advice.
#4019
#4020
it's all done through vtuning...
