TTS Mastertune Information
Old 05-02-2013, 05:06 PM
jamiegiroir@gmail.com's Avatar
jamiegiroir@gmail.com is offline
Default 2011 Ultra limited adding cams
I already have my bike tuned and I am adding cams should i just work from my current tune i cannot find anything closer the tune that feuling has on their website doesnt look very refined. Also im helping a friend with a 2009 street glide tts doesnt seem to have many options we are adding AC exaust cams, whats a good starting tune.
  #3752
Old 05-02-2013, 05:43 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
stage 1 bikes have a good tts base cal and list the specs on your cam, my guess is you will find a base cal that is similar as there are only so many different grinds.
  #3753
Old 05-05-2013, 05:11 PM
green53's Avatar
green53
green53 is offline
Default posting graph
I cannot find hoe to post my VTune graphs, please help. Thanks.
  #3754
Old 05-05-2013, 07:13 PM
Fat Cat's Avatar
Fat Cat
Fat Cat is offline
Originally Posted by Fat Cat
Just ordered my TTS and Stage 1 air cleaner from Fullsac. Within a month, I'll add Fullsac header pipe. I'll get the header pipe and installation done from my dealership. TTS and air cleaner will arrive this week. Thanks for the advice Wiz.
But one question. Alice said Steve will send me the 2012
Triglide download but she said it is meant to be added in conjuction with the header pipe and air cleaner...slip-0ns could be added last. So the question is.....Still add the TTS and Steve's download even though I don't have the header pipes yet? (I'm determine to tune this myself but obviously my knowledge is limited but I want to learn and hopefully not do something that can't be undone.) Thanks.
UPDATE. S&S air cleaner installed. Fullsac header pipe installed. TTS Master Tune installed. Flashed Steve's download. A significant difference in performance and I really haven't tuned it further or changed exhaust yet. Can't comment on heat reduction because high today was 68. Many thanks to Wiz and the folks at fullsac for walking me through this process. Will write more when I get to a real keyboard. On phone now.
  #3755
Old 05-06-2013, 08:53 AM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
Are you using an MT8 calibration file? WHat cams did you install? What year and model bike?
Answer these simple questions and we can answer if you need a different base cal, or can continue with the one you have now. Here's the deal, tho... simply reusing your original base cal will NOT shorten the amount of work to tune. New cams change everything.
  #3756
Old 05-06-2013, 06:19 PM
nva71's Avatar
nva71
nva71 is offline
1st Gear
i'm a rookie at this ,so I'll ask a rookie question.I have a 2011 ultra dbw with se 204 cam installed,se stage 1 breather kit,adj. pushrods se lifters,fuelmoto 2-1-2 header,with rinehart 3.5" slip on mufflers.What map should I use for this build?Tts mastertune is my tuner.
  #3757
Old 05-07-2013, 01:08 PM
wurk_truk's Avatar
wurk_truk
CTD044-003. Make sure to run the cam tool. This cal is assuming you have a 96" engine. I like the various TD cals for this kind of set up. Things move UP instead of picking a calibration that is 'too much' and have to tone it down. The 'hidden settings' will work well for you, too.
You will REALLY like that 204 set of cams, too.
  #3758
Old 05-07-2013, 02:26 PM
jussunduuri's Avatar
jussunduuri
jussunduuri is offline
Talking How to save Vtune datacollection
I have stupid question ;
How to do it: " After saving the DataMaster VTune file, exit the DataMaster application"
Today i tried very first time, but I couldn't find any "save as button " ??
so help me ?
Thank you
  #3759
Old 05-07-2013, 02:35 PM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Received 2,043 Likes on 1,105 Posts
so help me ?
Thank you
When you start Datamaster and select what you want to record it asks you for a place and file name where it will write it to the computer.
When you stop the software recording and exit Datamaster it automatically saves the file to where you told it to be saved. There is no save button so you aren't going nutz.
  #3760
Old 05-07-2013, 05:01 PM
wurk_truk's Avatar
wurk_truk
That depends on whether you are using the black or blue VCI and the new or old software. Blue with new datamaster2, will save auto. Black running old datamaster, you will need to hit the save button when getting out of v-tuning.
Quick Reply: TTS Mastertune Information
