TTS Mastertune Information
#3641
Check out the DPI176-03
25 deg Injectors
Air Cleaner and Breather Kit
3 7/8” Big Bore Cylinders
3 7/8” High-Compression Forged Pistons
Performance Cylinder Heads
.569” Lift 258/268 Duration Camshaft
Race Exhaust
#3643
The HD06 is only for the CANBUS systems (Softail) It wouldn't hurt to go ahead and install/update it. You may find a buddy that needs your help down the road.
#3644
#3645
Better hurry.. not much left at the moment.
#3646
#3647
#3648
New to the forum and new to TTS. I have a 2012 Street Glide and just purchased a full (Kuryaken) exhaust system, and a/c. My question is I have downloaded a map from Kuryaken site to match the set up but have not programmed ecm yet.
2010-2012 103 AC Power Cell Crusher Mellow Mufflers.MT7
Will I need to run V-tune to modify this map or will it be good enough to run with for now?
#3650
Because I have read to many say that the mt8 files lock out the dealer from connecting. I have looked at both mt8 and mt7 and they are pretty much the same maps from what I can tell. Correct me if I am wrong. What is the benefit to running a mt8 over a mt7 file? Kuryaken said this was the map that I wanted to use for the setup that I am going with so I thought why not start from there. Like I said before new to the TTS.
