TTS Mastertune Information
Old 08-11-2012, 05:12 PM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
Originally Posted by Northwestsooner
Just returned from a 2700 mile trip to Sturgis and around the Black hills and home. My bike is running fairly well. TTS mastertune and the TW 777 cams perform great with the stock heads and stock compression if i kept the RPM at 3000 or above. cruzing at 70 in 6th gear is powerless. I am fixing to up the compretion to forged 10.5-1 and install the MVA heads. Is this a good combo or should I look into something else? I want to keep the bike reliable for long road trips. But would like to have a little more snort in the low end.
MVA heads will require pistons designed just for them. I have MVA heads on my 120R, but that engine was designed around those heads. For a street/touring bike??? If it was me??? I would have my original heads reworked and buy a 107 kit from someone and be done.
  #3472
Old 08-12-2012, 08:49 AM
MadMike11's Avatar
MadMike11
MadMike11 is offline
Stage I
Default Base Map for FXDC w/Thunerheader
Does anyone have a base map to start with for a 2007 Super Glide Custom, bone stock - adding BigSucker AC and Thunderheader 2 into1.
Thanx,
Mike
  #3473
Old 08-12-2012, 03:25 PM
Northwestsooner's Avatar
Northwestsooner
Northwestsooner is offline
Thanks for the advice. I just talked to a builder and he wants me to pull my heads and jugs, send them to him. He will rework the heads with bigger valves, a different valve angel, flow bench the heads and get .010 over 10.5:1 forged pistons and fit them to the bore. Will be considerably cheaper than MVA heads and piston. I leave to the middle east in a couple days so i had better get to work.
  #3474
Old 08-13-2012, 11:11 AM
user 46092's Avatar
user 46092
user 46092 is offline
Thanx,
Mike
Start your tune with CAE176-03.
  #3475
Old 08-22-2012, 01:25 AM
tionestat's Avatar
tionestat
tionestat is offline
Default andrews 48h
Guy's, Looking for some help. 2007 SC, andrews 48h, rinehart tds (that I modified the baffles in) SE intake, had a SERT but had it up graded at TTS. Now I need a good starting point. Can ya help a brother out?
Thanks
  #3476
Old 08-22-2012, 06:54 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Received 2,043 Likes on 1,105 Posts
Thanks
Do you mean a donor calibration or chose a starter cal from their software?
Really doesn't matter which you flash as no calibration will be exactly what you need as you will need to use the VTune software to set your VE tables.
If you are given a donor cal then it is possible you continue with their mistakes.
  #3477
Old 08-22-2012, 08:19 PM
tionestat's Avatar
tionestat
Wiz, I've looked at the different maps as a starting point but when I find one that's close it's for a TBW. I'm not the sharpest knife in the drawer when it comes to this stuff so any help you could give me would be fantastic.
Thanks
  #3478
Old 08-22-2012, 08:37 PM
Mr. Wizard's Avatar
Mr. Wizard
Thanks
DQA176-03
Start here
  #3479
Old 08-24-2012, 08:57 AM
Depdog's Avatar
Depdog
Depdog is offline
Originally Posted by Lonewolf176
IVO from cam analyzer and IVC from cam estimator.
Sorry for the delay, got really busy around here. Life kinda gets in the way. I used the Cam Analyzer and got a 5 for IVO. The cam numbers I found online (2 different ones) and using the estimator called for a 2 or a 3 in the IVC. So I went with 3 because it was a high 2 or low 3.
So my cam settings are 5 and 3 and I have done 2 vtune runs under 3500 rpms. Got to download a program to my wife's iPhone so I can view the data live as I collect it. Want to get as many green boxes as I can in the next few runs and also raise the rpm's to get more usable data.
Will update when I have some more data runs under my belt.
Thanks
Glenn
  #3480
Old 08-26-2012, 03:44 PM
BKSinAZ's Avatar
BKSinAZ
BKSinAZ is offline
Is there a TTS for a new 2012 Super Glide? I was told they do notmake one 2012 SG bikes.
Quick Reply: TTS Mastertune Information
