TTS Mastertune Information
Old 11-25-2011, 06:18 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
Originally Posted by Pine Tree
OK, I'll ask...what problem is that?
If you use MT8 and fail to save your stock ecm cal you can not reload a stock cal back into the ecm if you did not save it in the first place. Like wurk truk said that is not a problem if you are not going back to stock ever. If however you decide you need to go back to stock for some reason if you did not first save your stock cal you are out of luck.
  #2972
Old 11-25-2011, 06:27 PM
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
Originally Posted by mtclassic
If you...
Got it! Thanks!!
  #2973
Old 12-21-2011, 02:01 AM
StreetGlider11's Avatar
StreetGlider11
StreetGlider11 is offline
Stage IV
Quick question...are you guys having good luck with the optional maps or do you end up tweaking them to suit the bike better?
  #2974
Old 12-21-2011, 05:15 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Some will tell you they see an improvement with the starting TTS map over the factory installed map with no further adjustments.
Most others have found just adjusting the VE's help a lot. And once that's done, the other tables get the bike even closer to a more efficient/better running/performing bike.
  #2975
Old 12-24-2011, 08:07 AM
Gadgetech's Avatar
Gadgetech
Gadgetech is offline
Default Looking for help w/ a TTS issue I'm running into
I finally got a mount for my iPhone so I could have a remote view of my computer screen while doing vtune runs. Yesterday was my first time out w/ the setup and something extremely annoying happened over and over and I've posted on other forums and haven't found an answer yet. While recording data, datamaster would freeze up and stop recording for a period of time and it always froze up when the data points were on a number like 5100, 5500, 6100 meaning whatever number it froze on had "00" as the last two digits. I'm not sure what's causing the issue if it's the iPhone RDP I'm using or if it's the computer.
1. Laptop is in a backpack on my back so there shouldn't be vibration issues
2. The freeze happens when the data piont ends w/ "00" and for an unspeicifed amount of time
3. When reviewing the data, you can see from data point 5100 to 5101 a pretty significant drop in RPM and it's that way for every data point I could remember it happening
I'm not sure what else would be helpful info. One of the forum memebers is looking at the data recording to share their thoughts but I'm still looking for an answer.
  #2976
Old 12-24-2011, 08:35 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Received 2,043 Likes on 1,105 Posts
Moved the above thread to the TTS section for a better response.
  #2977
Old 12-24-2011, 09:59 AM
mtclassic's Avatar
mtclassic
I had to vtune. The suggested download dta044 for my application did not feel as good as the stage 1 factory download but after several vtunes it feels very good for a stage 1 103.
  #2978
Old 12-24-2011, 11:28 AM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
Does it do this on a v-tune run when NONE of the iphone crap is hooked up? Proper troubleshooting technique is to cut the problem in halves... over and over. So, lets see if it is the ad hoc to the iphone or is it on the pc side of things. The ad hocs have a few issues and is why I hard wire a monitor from the laptop. Try a long run with nothing but the pc running in your backpack. Still getting these anomalies? Are you running serial connector or a USB conversion? We have found that only the authorized TTS converter and the Belkin 409 works well, others drop packets. Are you running Win7 64bit? Serial converters do not work well in 64bit.
look here... http://www.clearchain.com/blog/posts/how-to-use-a-belkin-f5u409f5u409-cu-usb-to-pda-serial-converter-in-visawindows-7-64bit-mac-osx-10
for the 64 bit fix.
  #2979
Old 12-29-2011, 12:34 AM
StreetGlider11
Stage IV
Thanks for the feedback guys. I called Phat Performance and ordered my TTS for $350!!
  #2980
Old 12-30-2011, 08:45 PM
wurk_truk's Avatar
wurk_truk
I sent Wizz a PM.
Quick Reply: TTS Mastertune Information
