Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a 2010 Road King. 96 with Rush 2" slip on with the CAT cut out and stage one air filter. Had it dyno and it runs good. Will it do any good if I vtune the map?
Thanks
Paul
Thanks
Paul
If you have already paid to put it on a Dyno and it runs good then there is no real reason to VTune unless you simply want to check the Dyno work.
