TTS Mastertune Information
Old 08-29-2011, 08:13 PM
blusmbl's Avatar
blusmbl
blusmbl is offline
Originally Posted by Pine Tree
I guess it's a relative amount.
Looking at the newest tables for late model bikes, the idle (15 kpa) column is now using an equivalent AFR of about 12.9 which is about 3 times the difference of the 14.6 & 14.2 figures.
Close. The 15 kpa column is the decel area with throttle closed. 20-30 is the idle region, which is still in closed loop in all of the stage 1 style cals I've checked.
  #2772
Old 08-30-2011, 06:42 PM
Smittyjf's Avatar
Smittyjf
Smittyjf is offline
I posted this in the EFI thread, but no response yet so I thought id try here.
I Traded in my 09 SG for a 2012 EG Limited a few days ago and can't stand the stock exhaust. The consensus is upgrading and tuning is no problem within break in as long as I don't go apeshit on trying to fill in all the cells during my tune sessions.
My 09 ran great with my master tune so here we go again with another 400.00 dollars for a new module. Good thing my V&H rounds and SE A/C could be reused to save a little.
I've done the tts updater and found 2 sections on 2012 touring maps.
One was:
2011-2012 DBW Touring Closed Loop and i'm looking at DTA044-03 for my 103 A/C, Factory 2:1:2 exhaust.
The other section below it had:
2010-2012 DBW Touring Closed Loop and there it has DTA009-03 for the same 103 setup.
I'm not sure what base would be best. the one that has 2011-2012 were just added, so probably the best to start there with the DTA044-03.
Any opinions?
Smitty
  #2773
Old 08-30-2011, 10:44 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
I used dta044 on my 2011 103 stage 1 air cleaner and free flowing mufflers and it worked very well. I since put on a supertrapp 2.1 and still using the same one.
  #2774
Old 08-31-2011, 09:41 AM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
One was:
Any opinions?
Smitty
IMHO,..... Use the 044 series of tunes for the 2012. It IS confusing in the cal listing, but the 44 cals are made for the 12s. There isn't much difference... but that 'not much' encompasses the new TB the 12s have.
  #2775
Old 09-02-2011, 07:29 AM
jamiegiroir@gmail.com's Avatar
jamiegiroir@gmail.com is offline
Mr Wizard I have a 2011 Ultra Limited with Reinheart classic duals and SE air cleaner I started with a tune that you did for a friend of mine Brian Anderson same bike only diference is he has the true duals not the classic. My question is after the V tune it seems to get hot at idol and the EITMS is not working. Should i mess with the VE tables or the main lamba table to fix this. What temp should I be able to maintain.
  #2776
Old 09-02-2011, 07:40 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Received 2,043 Likes on 1,105 Posts
Howz Brian doing? Haven't spoken to him in some time.
Getting hot at idle could be the fact it has been in the high 90's here. If not, sounds like you still need to work on your lower RPM VE range. If you used his calibration and it is the one that I set up for him then it is the .mt7. You may have better luck with the .mt8 so you can work with your EGR Tables and Cam Selector.
If you send me your finial calibration and your last VTune file I'll take a look. I'll email you a note.
  #2777
Old 09-02-2011, 07:48 AM
Brian has been fine not rideing much he broke his foot earlier in the summer he is better now. Ill send you those files. It seems to want to keep climbing temp at idle and cools off when on the gas.
  #2778
Old 09-02-2011, 08:17 AM
Mr. Wizard's Avatar
Mr. Wizard
Your front cylinder is way too lean. Need work.
  #2779
Old 09-02-2011, 07:19 PM
Smittyjf's Avatar
Smittyjf
Smittyjf is offline
Hey Wiz,
Im starting over again. Just as I got my 09 SG tuned the way I wanted it, I go and do a stupid thing and trade it in for a 2012 EG limited.
Now were working with Lambada which I know just enough to be dangerous with.
I started with the base CAL DTA044-03 and again ran came tune and even though it had an upswing at 5 and larger at 6, I stuck with stock 4 since that was the best Idle.
I changed my Lambada table to 0.981 in all cells from 15-90kPa (the DTA files have 95kPa column before the 100) and it will not go to 0.981 so I left it stock along with the 100kPa column according to the guide.
I set the PE to 10,000 and left the DECEL and ACCEL tables alone. Not sure if this was right since the new MT guide does not say to set to 0.
I ran my vtunes (4 total) and have pretty good VE results.
My question is how do I set the AF ratio I want. I set the Lambada tables back to Original and all the other tables and Constants back too.
The stock settings for this base map are in the 3 cells on the top of Mastertune program.
14.68 Stoich
14.45 AFR
0.984 Lambada
Did this AF ratio need to be changed before I ran my Vtunes or is that where I set it to what I want afterwards
Once I get the learning curve down with Lambada I'll be good.
Smitty
  #2780
Old 09-02-2011, 07:56 PM
Mr. Wizard's Avatar
Mr. Wizard
Hey Wiz,
I started with the base CAL DTA044-03 and again ran came tune and even though it had an upswing at 5 and larger at 6, I stuck with stock 4 since that was the best Idle.Did you work with your IVC? If not please do and use the best idle. If you fall on a different IVC then you must start your VTunes over.
I set the PE to 10,000 and left the DECEL and ACCEL tables alone. Not sure if this was right since the new MT guide does not say to set to 0.The Accel and Decel tables must be set to 0 so you need to continue on with your VTunes.
I ran my vtunes (4 total) and have pretty good VE results. When you VTune you should work with your EGR Analyzer. This will help smooth your VE tables, increase your bottom end TQ and give you better throttle response as well as better MPG. The trick with the EGR is to get the blue dots on the red line. Big adjustments at the lower end and smaller adjustments at the higher range up to 60 kPa.
14.68 Stoich
14.45 AFR
0.984 Lambada
Once I get the learning curve down with Lambada I'll be good. You now have Lambda, deal with Lambda terms. Set all Lambda to .981 except for the last two columns. Doing this puts all cells i closed loop. Your 02 sensors will not work with the ECM or the VTune unless your cells are in closed loop. After your last VTune and you have a smooth 3D graph for both cylinders put your Lambda back to original. There are a few tricks to help stay cool at idle and tricks to increase idle up throttle by taking those Lambda cells out of closed loop.
Smitty
Comments in red above
Quick Reply: TTS Mastertune Information
