TTS Mastertune Information
#2651
Thanks for the advice. I have soooo much to learn here. I don't even understand what VE really means yet, but I do have an engineering background and an inquisitive mind.
I will keep your recommendation in mind about the "speed" comment. My goal for now is just to richen it up.
I will be very interesting in seeing how the VTune process works. Looking at the base map, it appears the AFR's are mainly stock (14.6) and that would lead me to believe I am looking at the same EPA type ratios from my Stage I download.
I am hoping the VTune exercise will lead me to understand my first set of questions about AFR. After reading some of the manual last night, I am confused about the best method to adjust the ratio. It appears there are 3 different methods, AFR, Lambda and one other that I can't recall right now. I am hoping to start seeing some of that as I record. Any tutorial information (posting or a link) would be most appreciated.
For now I can sit down for some breakfast while mistake #2 is being fixed (running the battery down).
#2652
Step #1 is saving your factory calibration.
Step #2 is choosing a starting calibration (common mistake is to choose one too big)
Step #3 is Cam Selector (don't take for granted the cam selection is correct)
Step #4 is setting up a VTune calibration
Step #5 is to calibrate your VE's (everything works off the VE numbers)
Step #6 is to work with your EGR
Step #7 is to take all this information and transfer it to your starting calibration
...and the list goes on. Timing is a real pain unless you can see your changes on a dyno. You can't rely on the seat to find increase or decrease performance unless you can print out your TQ and HP chart while working with timing. Guess is not good enough. If in doubt, leave the timing alone and just make sure you preform a few datamaster recordings and look for knock retard. Make a few adjustments in VE's first then make your adjustments in retarding timing to eliminate knock.
The more you work with this the easier it will become. Good luck and stay safe.
#2653
Excellent advice. I would have done things differently based on ignorance. I don't plan to do anything without understanding the background and effects. I get your message of caution on the timing.
I can't wait to understand this in detail.
I read a little about stoichiometric principles over breakfast. Just a little light reading. I have a much better understanding in the relationship of AFR and Lambda now.
#2654
Mr Wizard,
Wow, getting the cam figured out took a lot more research that I thought. First, I couldn't find the Intake open and close for the stock cam. Once I did, it appears the map I started with is way off. Could it really be possible?
I started with CPZ176-03-a0. The description is 06-11 Touring with A/C and exhaust. Which would mean the stock cam.
There is stock cam specs on the Andrews and Nightrider sites and it appears they have different specs. Andrews appears to show Intake Open/Close to be -9/25 for '07/08 and Nightrider shows 02/34 for TC88. I have an '07 Ultra.
First, can someone help me locate the stock cam intake open/close? Second, if the value is negative, what does that mean?
#2655
I found yet another reference that seems good, however, I still don't understand how to interpret a negative number.
The reference is on the Nightrider site (http://www.nightrider.com/biketech/d...erCamSpecs.pdf)
It indicates that 2006+ have a stock intake open/close of -4/40. Does that mean that the intake is 4 ATDC vs. 4 BTDC? I interpret the close to mean 40 ABDC.
Any help with the interpretation would be appreciated
#2656
#2657
Jim,
Thanks for the information. It's great data, now I just need to understand it. Hopefully, this will happen as I get through the process.
The first interesting point was that I had an assumption that the cam values would be static. It is interesting that you had to manipulate them to get the best out your tune.
The learning will be to understand how each of these parameters impact the tune
Thanks again
Thanks again
#2658
#2659
Frustration is setting in. I can't get the VTune to work like I expect. It seems to stop taking readings after a short time frame. It works when idling in the driveway and then seems to go into a "waiting" state. I can't get any samples while riding.
I'm still playing around with the menus to understand how to really capture data while I ride around heating up my bike thinking I producing some useful test data
#2660
Be sure your computer is all set up so it won't stop working including any hard drive anti-shock program.
