TTS Mastertune Information
#2432
When you have time take a look at your EGR values to help smooth out the low VE areas up to 60 kPa. It will also help with the low VE's at idle too.
#2433
Do I use the The EGR Effect TPS Analyzer in Datamaster to do this? Not sure I have time to do anything else before I leave on a trip. Any detrimental effects on the engine if I wait til I get back from a 4,000 mile trip?
#2434
#2435
Lonewolf,
Thanks for the tip. I hope so, because that would explain the 1600mV number that I see most of the time would actually be 650mV or a lambda of 0.997. That lines up perfectly with 0.981 I ran during the VTUNE.
Thanks,
Robert
Thanks,
Robert
#2436
#2437
He everyone, love the discussion on TTS here! I'm a newbie and have a question about O2 sensor readings. When doing a VTUNE run, both the sensor activity lights stay green and the Waiting/Good light indicates Good. When I look at the data for the O2 sensors, they show 1500mV most of the time. They do indicate 900mV sometimes, but not toggling constantly like I expected. The bike is 2011 FLHTK completely stock except for BigSucker A/C. Anybody else seen this before? Output from VTUNE looks resonable.
Thanks for any help!
#2438
When restoring the original cal back in the bike how does the tts know I have it on a memory stick? I don't see no way to load it like you do a tuning file This might be just a dumb question but I just don't want to hit restore without checking first, not sure if it will damage something if I do it wrong... Pete
#2439
