TTS Mastertune Information
Old 02-21-2011, 08:48 PM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Received 2,043 Likes on 1,105 Posts
Head Quarters Black Ops are the most quiet lifter i've worked with.
Pricey though
  #2022
Old 02-21-2011, 10:21 PM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
ok ordered a set.
thank you mr wizard
  #2023
Old 02-23-2011, 06:21 PM
Reaper_ggy's Avatar
Reaper_ggy
Reaper_ggy is offline
Does the TTs Mastertune only good for one bike like the sert ?
... found the answe theyres kit for 1 or 2 bike
  #2024
Old 02-25-2011, 06:40 PM
blusmbl's Avatar
blusmbl
blusmbl is offline
Dumb question about the datamaster tool, is there any easy way to get it to export all of the variables to .csv without having to pick each one individually?
  #2025
Old 02-25-2011, 08:15 PM
Mr. Wizard's Avatar
Mr. Wizard
As far as I know you can only export one table selection at a time.
If you are talking about each cell in a single table being picked individually you can choose, or highlight, each cell by clicking on the button at the left X and Y axis such as... on the AFR or Lambda table simply click the RPM button.
  #2026
Old 02-25-2011, 08:59 PM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is online now
Once you have set up the variables in the data export tables just save the changes when you exit or open another data file. Then the next time you export data it will display all variables you previously selected.
  #2027
Old 02-25-2011, 09:49 PM
blusmbl's Avatar
blusmbl
blusmbl is offline
Excellent, that will do it. Setting it up once isn't that bad.
Thanks guys!
  #2028
Old 02-26-2011, 02:25 PM
voodoodrug's Avatar
voodoodrug
Pricey though
just got back from a ride with the black ops and you hit the nail on the head,mucho thx
bike runs like a swiss watch. tick gone,bye bye. engine is no louder then stock,think I will pass on a dyno now and just reflect on how great the bike runs with your help and a few vtunes.
  #2029
Old 02-26-2011, 02:41 PM
Mr. Wizard's Avatar
Mr. Wizard
Good deal
Only had a few not pump up right away. Started soaking them before installing then cranking without plugs to get the oil pressure up first. No troubles since then.
They are a good product.
enjoy...
  #2030
Old 02-27-2011, 03:49 PM
Raiderse's Avatar
Raiderse
Raiderse is offline
Default Running lean
I tuned my 2010 Heritage Softail with the stage one map , the O2 Sensor voltage was set to 486 this is an AFR of 14.45 or a Stoich of 14.68. The plugs are showing that is it running lean. I tuned until all cells were corrected after 4 runs. I would like to richen it up to maybe like 14.2 the voltage table shows that to tune it to 14.2 the Voltage would have to be set way of center on the graph (Voltage Calculator) so it would not be recommended. Talked to TTS Mastertune tech support and was told that they wouldn't set the voltage higher that 625. They said that the O2 Sensors were very narrow band and if set higher would loose range and would not work properly. That would be a little richer but nowhere near 14.2. Are these O2 sensors such that the APR cant be set much lower that 14.6 without them not functioning correctly? The band is very small according to the voltage calculator. So the last question I guess would be should I take my final tune and set the O2 Voltage to 624 and retune? Or should i start with the Mastertune stage one map for my bike and set the O2 voltage higher and tune again? A bit disappointed that it is not reliably able to set the AFR to 14.2. But, I would like to make it richer than it is because the plugs are showing white, not tan a lean condition. I was thinking when I purchased that i would be able to reliably set my AFR to 14.2 or 13.8 if desired. I have not started to tune my Crossbones yet and the plugs are a nice tan color on the same fuel.
After the tune the Heritage is running leaner than the Crossbones with the factory map. Seems to run well but the plugs are showing a lean condition. Is there a way to set the AFR as target so to tune for 14.2 in the Closed Loop mode reliably? Should I change the voltage table on the current tine and retune or should I start with the Stage one A/C config file ,set eh voltage and start to retune from there?
Thanks for any help, guidance or advice.
Quick Reply: TTS Mastertune Information
