TTS Mastertune Information
#1962
So... let's try something else.
Put the new dyna TTS on your CVO and see if you can connect and see the ECM. As long as you don't try to flash the CVO ECM you will not harm the new TTS or marry to it. Any TTS can view DTC info and or record data or view the serial number on any other ECM without being married to it...
If the TTS will recognize your CVO then you've eliminated the computer, all cables and the new TTS. That would leave what we discussed.... the ECM pins.
#1963
It was "on"... MBlaster and I were on the phone and I even got into his computer... the com port is OK but the ALDL is not being recognized similar to the Run switch being in the off position.
I've never seen a bad TTS or even a bad SERT that was straight out of the box new. I guess it could happen but if it was a bad VCI it would be a rare case.
#1964
--Gary
#1965
It's just weird. (used connector with three pins, not four) MasterBlaster is no dummy, he knows this pretty well. We have common friends so we chatted to get it working.
If the system works on his CVO then I think I understand what's going on.
Haven't seen you around for a while... Hope you are well.
-wiz
#1966
Already did Gary....
-wiz
-wiz
been busy...Chop wood, carry water!
--Gary
#1967
#1968
HogFlash??
#1969
