TTS Mastertune Information
Old 01-29-2011, 10:29 AM
Jhugues's Avatar
Jhugues
Jhugues is offline
Hello everyone, I am new to the forum and I have found this thread very helpful to help me choose a Mastertune TTS.
Now that I have received it I would welcome your opinions on which calibration file I should use for an International Ultra Limited with AC and SE slipon mufflers. I am leaning towards DTQ009-01 (all mkt 103 touring) but the piston things bothers me. There is no ac exhaust all mkt touring.
Thanks in advance.
  #1952
Old 01-29-2011, 02:11 PM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is online now
The all market touring calibrations allow control of the active exhaust option on the international models. You can flash your bike with it and disable the active exhaust. Then you could just reprogram with another map, such as DTA-009.
  #1953
Old 01-29-2011, 04:36 PM
Jhugues's Avatar
Jhugues
Jhugues is offline
Got it!
Thaks Lonewolf176
  #1954
Old 01-30-2011, 05:40 AM
masterblaster's Avatar
masterblaster
masterblaster is offline
Bike is back together ready to do the download. You mention tweaks to teh map to be downloaded, what tweaks are you talking about?
Originally Posted by Mr. Wizard
Yes but it will take a little bit of a configuration change within the new calibration. The 570's are a 20/40 intake * so this will not be an issue at all.
Once the calibration is tweaked for your build you should be close to what you are looking for but if you can do your VTunes the bike will run much better until you can dyno.
Your base calibration should be the CAA176-002 or the NI176-002 (closer to your cam specs). Do you have the TTS software yet?
  #1955
Old 01-30-2011, 07:36 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Received 2,043 Likes on 1,105 Posts
Each tuner has his own bag-o-tricks. Have you loaded up the new calibration yet?
  #1956
Old 01-30-2011, 07:40 AM
masterblaster
I can get the com to connect through.
  #1957
Old 01-30-2011, 07:47 AM
miacycles's Avatar
miacycles
miacycles is offline
You may need to make sure that the com port setting is correct. Whatever com port you have the USB cord plugged into has to have that number set in the program. You can find that out by going to system-then hardware profile-then com ports, once you are there you should be able to figure out which one is the device that you are using. Hope this helps.
  #1958
Old 01-30-2011, 07:50 AM
masterblaster
Yes good suggestion thanks, I checked already and in the tts program. Like your sig quote
  #1959
Old 01-30-2011, 07:53 AM
Mr. Wizard's Avatar
Mr. Wizard
PM sent
  #1960
Old 01-30-2011, 02:27 PM
masterblaster
I hit the wall, still cant connect through to the TTS and the ECM, changed laptops, ran DTC on the ECM everything checks out, only thing left to do is order new cables.
Quick Reply: TTS Mastertune Information
