yet another SERT ???/
Old 04-11-2006 | 12:04 AM
roady's Avatar
roady
Default yet another SERT ???/
I cant seem to find the answer to this ? Can you put the original factory setting back in the ECM ? I have an 06 Roadglide with 95" kit with 203 cams and SERT. Problem is I cant find a tuner anywhere around where I live in MD to tune the SERT. If I put the original setting back in I can get a Power Commander installed by a very reputable tuner for about 500-600 bucks including the Power Commander. The tuner said that I would need the factory setting back in the ECM though. Thanks for any help.
Old 04-11-2006 | 12:16 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: yet another SERT ???/
Yes, You can re-install the stock flash... Your dealer will have to do it though...
Old 04-11-2006 | 05:50 PM
Dan B's Avatar
Dan B
Maybe a dumb question, but why hasn't the SERT a map with the factory setting?
//Dan B
Old 04-11-2006 | 08:27 PM
roady's Avatar
roady
Dan B I didnt quite understand your ??? but I am using a factory setting now that is close to my build but the factory setting is using the Sceaming Eagle pipes and I am using the Rinehart True Duals and from what I hear is that is a big differance. Then I should still have it dynoed to fine tune but I cant seem to find anyone local that will fool with the SERT while doing the dyno. What does everyone here think of HDMAPS does there maps work well, I just talked to guy named Jay that seemed pretty helpful. I just wanted to check in with everyone here. Thanks for any help.
Old 04-11-2006 | 08:51 PM
Shovelhead Bob
Because it is a RACE Tuner... Stock maps aren't going to be used for a race application...
Old 04-11-2006 | 09:27 PM
roady's Avatar
roady
does anyone here have a map for my application that they would like to share. My application is: 06 RoadGlide with Screaming Eagle Stage 2 95" kit with 203 cams and SE AC and Rinehart True Duals or do I spend the money on the HDMaps site and try and find someone that can dyno it .
Old 04-12-2006 | 03:11 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
You may want to rent a trailer instead and trailer your bike to a full service dealer who can dyno it for you for $300. Everything I have read tells me the SERT is better than the PC if dyno'd by a competent tech. So go on the HD website to the dealer locator section and find a dealer who will dyno your bike and give you a copy of the map on CD as well. It can't be that hard.
pillows
03-22-2012 09:39 PM
1931jamesw
05-15-2011 06:28 PM
ambrose
04-13-2010 10:28 PM
Protrucker
17
01-21-2008 11:56 PM
cdn.biker
02-03-2006 02:52 PM
