thundermax base map
I would think that woudl work. when I got my thunder max and ask Jamie at fuel moto to install base map for my custom design pipes because the pipes are not listed in the base map it work. the only things I experienced was at idle but that was easy fix also. All I had to do was clear and told it to learn. I woudl think any 2 to 1 map would work to get you going.
Hello, the D&D Fatcat 2-1 map will be a good starting point for you. I recommend clearing the learned fuel and IAC offsets when you load the map and initialize the unit.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
