Wide band
It looks like the new PCV can use WBO2 input.
You can use a Dayton Twin Scan II with WBO2 sensor input to create accurate fuel maps and use that as input for SERT/SEST/TTS. This allows a wide band sensor to be used on the bike to tune the ECM. The TSII is a very good "tuning tool" that can be used with any ECM and tuner.
You can also use Innovate LC-1 WBO2 sensor to emulate narrow band O2 output on one of their outputs to the HD ECM and use the second output for a wide band digital AFR guage so you can monitor your fuel mixture in real time.
So there are ways you can use a wide band O2 sensors with the OEM Delphi ECM. All depends on how well you understand NBO2 sensors, the OEM ECM and some of the aftermarket components available.
