Acquiring a Simple SERT Printout
Hello All,
I would like to attain a (simple) readout of my bikes current EFI settings,
AFR, VE, Spark Advance, etc.
I am looking at Page75 of the SERT Tuning Manual. Is this the correct page to use to attain the info?
I just want to make sure that I do not change the current Data File in any way prior to retaining the current setup data.
Any guidance in this respect would be appreciated.
Thanks,
Butt,
Thanks,
Butt,
You are not able to retrieve the tuning tables. This is why you must save the file every time you make a change to the calibration. Also if you have you bike dyno tuned make sure you get a copy of your SERT file.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Page 75 in the tuning manual describes how to print out a data record from data mode. All you get is a screen shot of what you're looking at plus any file comments you may have added.
If you want to print out the tables from a tuning file, you have to open the file in tuning mode. Click 'file' then 'print table' or 'print all tables'. This prints out what is in the tuning file, not necessarily what is in your ECM. If the tuning file you have open is what's loaded in the ECM, then obviously what you print out is what's in the ECM.
