TTS DataMaster - configuring frames?
Is it possible to configure what constitute a frame in DataMaster? By that I mean tell it I only want certain values so that less data is being sent over the bus and thus I can get more frames per second. Or is a frame always all the values? I know I can configure what gets displayed, but that doesn't seem to affect what gets logged from the bus.
There is a limit on the buss transfer rate from the ECM. I do not remember it off the top of my head but if you collect Dyno data that runs the buss wide open. Check and see how fast that is on your system and compare to the rate your seeing in the normal mode. You can speed things up by selecting the graph not to update while recording too. It's all in the manual about speeding the recording speed up. As far as any changes, not in the near future.
That not what I meant for you to do. What I wanted was for you to go collect dyno data and see what the collection rate is. Then go to the data you want and see if by cutting back on the display update rate you can get to the same data collection rate. If you can it's as good as it gets. Since it takes time for the PC to update the graph and screen while gathering data turning those off may do the trick for you. It all depends on the PC.
Bohemian
Ironhead
08-02-2014 08:20 PM
