99 Road King with DTC 35????
Yes, I've tried the search. I have a 99 RKC with 6700 miles that I picked up about a year ago. It had 3500 miles at the time. It has aftermarket pipes and the stage 1 kit. I changed spark plugs a year ago, did the 5000 mile service at 3700 miles and again at 6000 miles. It runs perfectly but threw two codes yesterday on my ride back from Daytona (about 100 miles) right after a very brief rain shower....just enough to get the bike wet. The codes were 16 and 35. I knew the battery was weak and probably the cause of 16, and when I pulled the battery this morning I found out it was installed 7.5 years ago, so it was definitely time for replacement. Installed new battery and code 16 went away but code 35 is still there (engine light on all the time still). The service manual states that code 35 is tachometer, except FLHRC-I, which just happens to be my bike. Since the Road King Classic doesn't have a tachometer, has anyone experienced a code 35, and how did you fix it?
Thanks in advance!
Thanks in advance!
