PCIII map for break-in.
I currently have a good map for my 96" with a Woods TW6-6. I will soon be installing jugs and SE Flat Tops(10:1) for a 103" using stock heads and can't find a break-in map to run prior to dyno tuning with PCIII.
The 103 is about a 7% increase in displacement over the 96". Would it be possible to simply increase the fuel map for the 96" by about 7% across the board and run that for break-in period on the 103" as I'll be using stock heads.
