decel popping
Bike is to lean at the 0 throttle position. Hook up you PCIII start your bike with the power commander program running and select get map. In the 0 throttle column (all the way to the left) change the numbers to 15 starting at the 1250 RPM range to 4,000 RPM. If it still pops on decel try changing the numbers to 20. My 06 worked with 15's.
Make sure you save that MAP with a different name.
Try it you will like it. If you don't like it you can reload your original MAP. Just make sure you save your original map under a name that you will recognize later like Dynotune 9-25-08.
What he said,,yes yes yes.
You can even start at say 18,,,ride it..if no popping...go down to 17...keep doing this until popping returns..then go back up one...
Do not change the 2% and 5% position columns. Popping occurs when you decel with your throttle in the 0 position. Put 15's in the left colum (0 Position) only. Like stated above you can try 10's or even 5's. The goal is to find the lowest number to put in the 0 throttle position colum that will stop the popping on decel.
