Is my amp draining my battery?
Old 09-22-2008 | 06:24 PM
NitroBerserker's Avatar
NitroBerserker
Unhappy Is my amp draining my battery?
I have one of the Harley Enhanced Stereo Sound amps on my 2001 FLHTC and it seems that it is always draining a little juice from my battery. I first noticed that sometimes the speakers would crack ( noise ) when I turned it off or on even without the radio on. Now if I don't ride it for a couple days it acts like the battery is low, and is slow to start, but once it starts and is run for a little while I am good for the day. The last time I just thought I would switch out the battery, I have a good stock battery in the garage so I pulled out the 1000A BIG BOAR battery and when hooking up the other I noticed a little spark, and heard the speakers crack again. well i put a tester across where the fuse was for the power lead to the amp and it was showing 1.3 V. This is with everything off. I checked the directions for the wiring and it is hooked up per instuctions. got a good headache reading those wiring diagrams in the manual, Ha-Ha. anyone else have any kind of problem like this?? can something in the amp go bad and be slightly drawing down the battery? for now I am just leaving out the fuse but that means NO Radio.
I dont think the radio turns on the amp because the trigger wire connects to the cigarette lighter and it only gets power when in ON or ACC. position.
1sweetglide08
Audio Systems
03-27-2013 04:35 PM
timmanis2000
05-19-2011 05:36 PM
rg_dave
12-12-2010 11:29 AM
jackinthebox
06-09-2009 10:48 PM
Quick Reply: Is my amp draining my battery?
