optimizing TMax for best mpg
I am running 103' with Andrews 37HG cams, ported heads, V&H bigshots, kuryakyn hypercharger and have just installed the TMax. On my first tank of gas I got 33 mpg. The second tank I got 37 driving conservatively. How do I go about modifying the map to increase my mpg through the cruise range?
Those are still the old maps with afr set to 13 to 1, You can either tinker with your existing map, I think it is easy to do, but I was always to chicken to do it or switch to one of the newer maps in the 4 and 5 hundreds, and if you are worried about it not tuning correctly you can set you adjustment up to like 35 percent away from the original map, Im sure someone that understands the tmax a lot better than me will tell you how to do all this but when I put my tmax in I set it and left it alone and it has been working great and I am afraid if I start messing with it I will make it worse. Todd
Weeboy1
06-10-2015 02:49 PM
disco
10-12-2013 08:13 AM
