rear tail and running lights out
Hi All,
Learned the my rear taillight is out along with both running lights. Brake light comes on but no running lights. Blinkers still work as well. Wondering if this might just be a fuse out since the brake/blinkers still work. Any ideas? Thanks in advance!
My bad!
True enough: misunderstood & thought it was the turn signal and tail light not working (also was working without a schematic). O/W wire supplies power form the ACCY fuse and the black is ground and are common leads for both fender tip running lights and brake running light circuit and numerous other circuits, such as turn signals, horn, etc. Brake light runs off the red with yellow (R/Y) wire circuit from the stop light switch. Looking at the schematic, I would check the front fender bulb to see if it's blown since turn signals and others are not affected, then check the O/W wiring from the ACCY fuse box for power to the rear fender or work from the fender to the fuse using voltage drop method until you locate the fault.
Robottom
11-17-2010 11:57 AM
