Headlight Blowing Fuses
2007 Electra Glide U/C has blown 2 headlight fuses in the past 2 weeks. I don't see any obvious causes and I'm pretty sure it's likely a grounding issue or a hot wire grounding out.
There is nothing else wired to this fuse...all gauges are reading normal.
Anybody else had a problem like this? What was your cause? Thanks for any replies....
