Kurakyn Panacea Lights (Deluxe Softail)
Well this is what I purchased:
Panacea Module
LED Bullet Front (2)
LED Bullet Read (2)
Tombstone Tail Light
Front Amber light work as well as does the rear tombstone light. The rear turn signals only one side works both are fine in the same socket. Does anyone know where I can get detailed instructions on how to setup the system. The front and rear have an additional load sensing module that say its need to be spliced but has a white connector that matches the module. What is the deal does it need spliced or does it connect into the module. Called Kurakyn closed for the day and weekend. Does anybody know of detailed instructions? Thank you.
Panacea Module
LED Bullet Read (2)
