Bad day #2
Bad day #2
Greetings again,
Well took my battery to the Harley Dealer and the machine printed out that the battery was good and was accepting a charge. I put it on a recharger and back intothe bike and it started right up. At least that should narrow the quest down to either the stater or the voltage regulator. I think that the only thing that I can do is put a voltage meter on each and see if the output is correct? Any thoughts or short cuts that you can provide? What should the outputs be? Thanks HELP!
