Is this problem caused by my ignition module?
I am having a problem with my 1996 FXDL on cold starts. The starts hard and runs only on the front cylinder until maybe a minute goes by and it has warmed up with the enricher on. Once warmed up it runs fine. When it is first started, as the bike is starting to warm up, the front cylinder fires 2 times to every 1 time the rear cylinder fires. This came on fairly quickly and I have since replaced the plugs to no avail. I have been hearing from people that it sounds like it may be my ignition module. What about the voltage regulator?? Any ideas would be appreciated.
Thanks
Thanks
Thanks
Thanks
The Ignition takes at least 9.5 volts to fire the plugs so if your getting fire at all I wouldn't worry about the regulator, however I'd clean the pilot jet in the carb and check the VOES operation. Also check the vacuum lines and manifold for leaks before I spent money on a new ignition module
Ignition module
Thought I would post the response to this now that the problem has been identified, in case someone else has this problem and use the search feature here. This did end up being the ignition module causing this problem. It was replaced and running fine. Very easy job to replace, and only took a few minutes. Trouble was, the cost of the part was more than $200 bones.
jtr
10-07-2012 07:02 AM
zenwarrior
09-15-2006 04:11 PM
