Spark Plug Questionfor 07 streetglide
I am using Autolite and they seem to work with the Ion sensing just fine. I thing the key is to make sure they are gapped correctly. From what I have seen the Delphi system is set up to work with a .040 thou. gap. I went a plug colder and on data logging sessions, can see the system removing timing, and I hear no ping. This is just my own observations, and experience.
I installed the Autolite 4163 which is one plug colder than what is called for 4164. DSanchez is correct you are not going to save money by doing this, I did this because HD to my knowledge does not make a colder plug, and I wanted to try and eliminate some detonation. My bike runs better with these plugs. I looked at the Delphi web site and they explain how their ION sensing technology works, and I didn't see where they say that you must use one brand over another. So I am experimenting and so far I like what I have done.
